Thrivecart to Membervault using Routers
Status: Closed · Asked by carlajayne on · 0 views
I am trying to connect my ThriveCart to Membervault. I have 4 different price points, and I need a few steps to happen. I'd love someone to talk me through this because I feel I've either missing a step or doing something wrong.
I have connected my MV and it works fine.
To give you context - I have monthly and yearly options for 2 tiers.
Any of the 4 payment options you are added to the product/course, and to another which is how I set it up. That works.
So, pay $99 or $149 a month or either yearly option: Added to main product and secondary product.
I want to add the higher tier monthly/yearly to two more products on top.
So, pay $149pm or yearly and ALSO get 2 products.
I tried to do that using routers but it's essentially adding to all despite adding them as only for the higher payment tier.
So I signed up as a test for the standard tier and it's added me to everything which is incorrect.
What am I doing wrong? This is the second workflow I've set up because I don't see where I can select the standard tier in routers only the upgraded.
Screenshots below.
I am trying to connect my ThriveCart to Membervault. I have 4 different price points, and I need a few steps to happen. I'd love someone to talk me through this because I feel I've either missing a step or doing something wrong.I have connected my MV and it works fine.
To give you context - I have monthly and yearly options for 2 tiers.Any of the 4 payment options you are added to the product/course, and to another which is how I set it up. That works.
So, pay $99 or $149 a month or either yearly option: Added to main product and secondary product.I want to add the higher tier monthly/yearly to two more products on top.
So, pay $149pm or yearly and ALSO get 2 products.I tried to do that using routers but it's essentially adding to all despite adding them as only for the higher payment tier.
So I signed up as a test for the standard tier and it's added me to everything which is incorrect.What am I doing wrong This is the second workflow I've set up because I don't see where I can select the standard tier in routers only the upgraded.
Screenshots below.
In filter step you need add static value. And why you are adding user two times Feel free to DM me and we can do a free zoom call. FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
I appreciate your response but I'd prefer one from the Pabbly Connect team.
Hello @carlajayne,
Himesh was correct in identifying the issue. While you have added a filter, the selected label and the mapped value are currently the same, which causes the filter to always pass. To resolve this, please use a static text value as shown in the third image you attached. This should ensure the filter works correctly.
Kindly try this and let us know how it goes.
