MrJohn17
I need assistance with an automation setup that I've created using ClickFunnels and Google Sheets via Pabbly Connect. The goal is for a new contact created in ClickFunnels to trigger the creation of a new row in a Google Sheet with their information. However, I'm encountering a problem where multiple rows (10 to 20) are created for the same contact instead of just one.
Here's a detailed summary of my setup:
Thank you in advance for your help.
-Scott
- Trigger: New Contact Created in ClickFunnels- App: ClickFunnels
- Trigger Event: New Contact Created
- Webhook URL: Captures the event and sends it to Pabbly Connect
- I have set up the webhook URL correctly and confirmed that the response is being received.
- Action 1: Date/Time Formatter (Pabbly)- Action: Format Date Only
- This step ensures the date is formatted correctly for the next steps.
- Action 2: Add New Row in Google Sheets- App: Google Sheets
- Action Event: Add New Row
- This step is supposed to add a new row with the contact's details to a specified Google Sheet.
Screenshots:
Steps Taken:
- Verified the webhook setup in ClickFunnels.
- Ensured that the Pabbly Connect workflow is set to trigger only once per new contact.
- Checked for any loops or additional triggers that might cause multiple executions.
Request for Help:
Has anyone encountered a similar issue, or does anyone have suggestions on how to resolve this problem? Specifically, I need to ensure that only one row per new contact is created in the Google Sheet. Any guidance or insights would be greatly appreciated!Thank you in advance for your help.
-Scott
