This documentation offers a comprehensive, step-by-step guide to integrating your Tutor LMS account with Pabbly Connect. By following these instructions, you can effortlessly establish a seamless connection between the two platforms.
==========================ACTIONS=============================
Tutor LMS: Create Course(Action Event)
Please follow the steps below to create a course for the above-mentioned action event:
Tutor LMS: Update Course(Action Event)
Please follow the steps below to update a course for the above-mentioned action event:
Tutor LMS: Delete Course(Action Event)
Please follow the steps below to delete a course for the above-mentioned action event:
Tutor LMS: Mark Course as Complete(Action Event)
Please follow the steps below to mark a course as complete for the above-mentioned action event:
Tutor LMS: Create Enrollment(Action Event)
Please follow the steps below to create an enrollment for the above-mentioned action event:
Tutor LMS: Update Enrollment Status(Action Event)
Please follow the steps below to update the enrollment status for the above-mentioned action event:
Tutor LMS: Create Topic(Action Event)
Please follow the steps below to create a topic for the above-mentioned action event:
Tutor LMS: Update Topic(Action Event)
Please follow the steps below to update a topic for the above-mentioned action event:
Tutor LMS: Delete Topic(Action Event)
Please follow the steps below to delete a topic for the above-mentioned action event:
Tutor LMS: Create Lesson(Action Event)
Please follow the steps below to create a lesson for the above-mentioned action event:
Tutor LMS: Update Lesson(Action Event)
Please follow the steps below to update a lesson for the above-mentioned action event:
Tutor LMS: Mark Lesson as Complete(Action Event)
Please follow the steps below to mark a lesson as complete for the above-mentioned action event:
Tutor LMS: Create Assignment(Action Event)
Please follow the steps below to create an assignment for the above-mentioned action event:
Tutor LMS: Update Assignment(Action Event)
Please follow the steps below to update an assignment for the above-mentioned action event:
Tutor LMS: Delete Assignment(Action Event)
Please follow the steps below to delete an assignment for the above-mentioned action event:
Tutor LMS: Create Quiz(Action Event)
Please follow the steps below to create a quiz for the above-mentioned action event:
Tutor LMS: Create Quiz Question(Action Event)
Please follow the steps below to create a quiz question for the above-mentioned action event:
Successful Integration:
Upon completing the above steps, your TutorLMS account will now be successfully integrated with Pabbly Connect. You can utilize different actions and triggers according to your purpose. With this integration, you can automate processes through Pabbly Connect, improving your workflow and enhancing your productivity.
If you encounter any issues or require further assistance, feel free to reach out to our support team for help. ([email protected])
Happy integrating!
How to authorize Tutor LMS in Pabbly Connect?
- Within Pabbly Connect, navigate to the action step and choose "Tutor LMS" as the action you wish to perform. Select an action event, such as "Create Course".
- To establish a connection, select "Add New Connection" and if you already have an existing connection, you can opt for "Select Existing Connection" instead.
- To establish a new connection, select the "Add New Connection" radio button, enter the API Key, Secret key, and Site URL, and click on the "Save" button.
- To obtain the API key and API Secret key, first, install the TutorLMS Pro plugin, then navigate to the tools section.
- Click on the Rest API and select the "+Add New" button.
- Choose the desired permission level (Read, Write, Read/Write, Delete, and All) and proceed to generate the API key and Secret key.
- Use Case: To create a course for your Tutor LMS account.
- Select "Create Course" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Post Title", "Post Content", "Post Author", "Post Status" and other custom fields.
- Click on "Save and Send Test Request".
- Use Case: To update a course for your Tutor LMS account.
- Select "Update Course" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Course ID", and other custom fields to update a course.
- Use Case: To delete a course for your Tutor LMS account.
- Select "Delete Course" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Use Case: To mark a course as complete for your Tutor LMS account.
- Select "Mark Course as Complete" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Course ID", and "Student ID" fields.
- Use Case: To create an enrollment for your Tutor LMS account.
- Select "Create Enrollment" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Course ID", and "User ID" fields.
- Use Case: To update the enrollment status for your Tutor LMS account.
- Select "Update Enrollment Status" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Course ID", "User ID", "Enrollment ID" and "Enrollment Status" fields.
- Use Case: To create a topic for your Tutor LMS account.
- Select "Create Topic" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Topic Course ID", "Topic Title", and "Topic Author" fields.
- Use Case: To update a topic for your Tutor LMS account.
- Select "Update Topic" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Topic ID" field.
- Use Case: To delete a topic for your Tutor LMS account.
- Select "Delete Topic" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Use Case: To create a lesson for your Tutor LMS account.
- Select "Create Lesson" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Topic ID", "Lesson Title", "Lesson Author" and other custom fields.
- Use Case: To update a lesson for your Tutor LMS account.
- Select "Update Lesson" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Lesson ID", and other custom fields to update a lesson.
- Use Case: To mark a lesson as complete for your Tutor LMS account.
- Select "Mark Lesson as Complete" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Choose or map the "Course", and enter the "Lesson ID", "Student ID" and other custom fields.
- Use Case: To create an assignment for your Tutor LMS account.
- Select "Create Assignment" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Topic ID", "Assignment Title", "Assignment Author" and other custom fields.
- Use Case: To update an assignment for your Tutor LMS account.
- Select "Update Assignment" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Assignment ID" and other custom fields.
- Use Case: To delete an assignment for your Tutor LMS account.
- Select "Delete Assignment" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Use Case: To create a quiz for your Tutor LMS account.
- Select "Create Quiz" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Topic ID", "Quiz Title", "Quiz Author", "Time Type", "Time Value", "Feedback Mode", "Question Layout View", "Questions Order" and other custom fields.
- Use Case: To create a quiz question for your Tutor LMS account.
- Select "Create Quiz Question" as an action event, connect your Tutor LMS account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize TutorLMS in Pabbly Connect?" section.)
- Enter the "Quiz ID", "Question Type", and other custom fields.
Happy integrating!
