Typeform entry is not fetching
Jobaaj
I have connected Typeform with my pabbly connect but when I am trying to trigger the event by new entry or want to fetch the response then it takes lots of time but still does not fetch the details. So what I have to do in that case?
Pabbly13
Hey @Jobaaj !
  • Kindly click on "Re-Capture Webhook Response" -
  • Once done, do a test submission in your TypeForm by adding a new entry to capture the response in the workflow.
You can refer on this video tutorial for the same-
Do check and let us know if it works for you.
