Upgrade /downgrade plan from checkout
Vzert
I am trying to integrate the PSB checkout into my saas. While reviewing the documentation, I found that I can create the customer using the API and then pass the customer id as a parameter in the checkout to prefill the data.
My question is whether there is a way to pass the subscription id as a parameter to upgrade or downgrade the plan using PSB checkout. Currently, if I only pass the customer id without the subscription id, a new subscription is created.
MukeshR
Active member
Hello Vzert,
Pabbly Subscription Billing offers API for upgarde/downgrade the subscription that you can use to upgrade or downgrade the subscription according to your requirement. To know about to this please refer to the below link
https://apidocs.pabbly.com/?version=latest#f38eb77a-8284-4847-b8c0-debbda138399
Additionally, we kindly request you to provide more details about your use case so that we can offer you an appropriate resolution. Your comprehensive input will help us tailor our support to better suit your needs.
Vzert
My problem is that I am creating the client with a subscription to a free plan, so initially there is no associated credit card.
If I try to use the API to upgrade, the payment fails due to the lack of a card.
I know I can generate a URL to capture the card through the API, but that view cannot be customized and the texts are in English, which would not generate trust for my clients.
So that's why I want to use the checkout view that has my texts and design, or I don't know if there is a way to customize the view to add a card.
D
Deleted member 12173
Hello, @Vzert
The card is not being added due to the limitations of the free plan; it can only be linked for plans with a price equal to or above $1. We recommend offering your customers a plan that exceeds $0 to address this issue. For guidance on customizing the checkout page, please consult the video tutorial on the Checkout Customizer.
Checkout Customizer
If you still have any questions, please feel free to reach out to us.
Vzert
I know I can customize the checkout, that´s not the problem.
The problem is the "Add New Card" view that has texts in English and doesn't look very professional.
MukeshR
Active member
Hello @Vzert ,
Right now, we don't have the option to customize the "Add New Card" page inside Pabbly Subscription Billing. Could you please provide feedback on why this "Add New Card" option appears unprofessional? I will forward your comments to the technical team so we can work on improvements.
Additionally, we kindly request that you submit this as a feature suggestion in our forum. If we receive multiple requests for this feature from our users, we will consider including it in Pabbly Subscription Billing after assessing its feasibility. Please find the forum link below.
https://forum.pabbly.com/forums/features-requests.26/
Vzert
Mainly, because it cannot be translated, all my clients speak Spanish and my SaaS platform, where I am incorporating PSB, is in Spanish. Displaying this view with English texts will generate mistrust, especially when they have to enter sensitive data.
MukeshR
Active member
Hello @Vzert ,
Thank you for providing the details. As mentioned earlier, currently, we do not have the option to customize the "Add New Card" feature.
We kindly request that you submit this as a feature suggestion in our forum. If we receive multiple requests for this feature from our users, we will consider its inclusion in Pabbly Subscription Billing after assessing its feasibility. Please find the forum link below
