Using Labels in Infinity
Status: Closed · Asked by wibbler on · 0 views
wibbler — Question ·
I would like to revisit this issue: https://forum.pabbly.com/threads/sending-from-shopify-to-infinity-label-attribute.7296/
The final solution (using square brackets) does not work any more. I'm unable to add to a Label field in Infinity using a Pabbly workflow.
The data sent is this:
And the error is:
Please can someone check my syntax accordingly? How do I get data to send in Values 0 Data?
My workflow is "BOX: New Box Order" and the Route is Note 4.
Hey @wibbler
Could you please share the name of the workflow in which you have tried the same?
wibbler — Reply ·
Seems like you were not passing the Label's Id in double quotes inside the square brackets.
Sample -
wibbler — Reply ·
Ah, that's great! Thank you for troubleshooting.
