Using Multiple Iterator
I want to use email to 100 users.
Data of each user is collected through GET Api.
Each Api response page contains 100 email ids
By using Iterator I am able to send email to these 100 users.
How can I use the same workflow to GET next 100 email ids and repeat
Hey @Anwer.nk[p
Could you please share the name of the workflow, so that we can check the possibility of the same?
Hey @Anwer.nk[p
Regarding your concern, you can use the Router action step where you can configure the individual API by Pabbly inside to run in a sequence.
I need to run the workflow on a scheduled basis.
Step1: Through GET function get the list of 500 users,
(reponse: You will get list of first 100 users, and in response there will be link to next page)
Step 2: SInce I have received the names of 100 Users, Using Iterator, I will take first name of user.
Step 3: Using API GET. I will take the contact details of the selected user again.
Step 4: I will send the selected user the required message.
___________________________________________________________________
This is repeated till 100 users received through the first API response. and using Iterator I am able to send the message to first 100 users.
Workflow stops after sending first 100 users
I want the workflow to GET next 100 users after this and continue until there is no next page.
Hey @Anwer.nk[p
You can set the individual routes in the router action step and inside you can see the Get API step to iterate the leads in flow.
In a similar way set the another get action step in another route to iterate the leads.
E.g. -
Thanks for the quick reply,
Since the number of users are growing, rather than creating router each time for next 100
Can I create next router automatically.
