I have created a workflow with a webhook, but it is not getting triggered. How can I tell whether the trigger is being received? Would this show in my history?
I was previously using a webhook to send to Zapier and it added a row in Google Sheets.
The webhook I created with Pabbly should trigger new bookings in Probooking to update a record in an Airtable base. I can't test this as the data I have in Airtable is different from the dummy record sent from Probooking. However, nothing happens when I create a new appointment in Probooking.
I thought I would try something simpler today.
I set up a workflow to insert a row in Google Sheets when I update/create a contact in Google Contacts.
The test works fine. Some time after I actually create a contact in Google Contacts, a new row in Google Sheets is created.
This at least confirms that one workflow is working.
Best wishes,
Anita
Best wishes,
Anita
