  • Our team is not available on 25th December 2024 due to the Christmas holiday. We'll be back on 26th December 2024.
    We appreciate your understanding as support responses may be delayed slightly.
Webhook received but not triggering
We have a webhook trigger that's supposed to fire a Google Sheet however even though it shows the webhook was received, nothing happens.
Hey @marioaldayuz
Could you please tell us if your data is coming from another application or you are manually feeding it? So if you getting data from a third-party application, in that case, you need to check both the options of "Send On Event" and "Auto Send on Schedule" and by enabling both the options then the data can be forwarded in 1hr. That is something associated with Google API and we cannot change or manipulate it.
And if you are adding the row manually then kindly select "Send on Event" only. Then try adding a new row to test the workflow.
The webhook comes into Pabbly (Pabbly Webhooks) then is supposed to route into the Google Sheet and add a new row.
Hey @marioaldayuz
Could you please share the name of the workflow which you are trying to automate? Moreover, try recapturing the webhook response again and map the " Google Sheets: Add New Row" action event.
