Webhook to GetResponse connection
I'm trying to create a contact on GetResponse whenever a webhook receives a notification. However, when I go to the contact on GetResponse, this is what I see: https://take.ms/Ky7tj I mean, the only option is for me to manually write a name and an email, but it doesn't seem to be gathered from the webhook, therefore I'm not sure if my webhook contacts will be connected to GetResponse. Am I doing it right or is there anything I'm missing? Thanks.
Supreme
Hey @benetmaria
Kindly refresh the page once and then try again.
Thanks for your reply. I can't find the name or email in the dropdown menu. I assume it's because the Webhook doesn't give this information, correct?
Supreme
Hey @benetmaria
Kindly check the data from the application from where you have captured the webhook response.
And then recapture the webhook response again with the name and email address.
