Whatsapp problems
Status: Closed · Asked by Influencers Agency on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjIwNTZlMDYzNDA0MzY1MjY0NTUzMyI_3D_pc
Task History ID: IjU3NjAwNTZiMDYzNTA0MzA1MjZiNTUzZDUxMzE1MTYzNTQzMiI_3D_pc
Until 1 week ago everything was working correctly, but today for some reason the messages are not reaching me on whatsapp (before they did), according to pabbly they are being sent correctly so I don't know what it could be, regards!
I checked facebook apps and it says everything is fine.
Hey @pablol44
Could you please let me know if are you using a free version of Whatsapp Cloud API? If yes, then kindly add the payment method, like a card into your Whatsapp Cloud API and then check again.
Let me know if it helps.
