WHMCS Create project doesen't send ClientID
purple
Your Task History ID
IjU3NjUwNTZjMDYzNDA0MzY1MjZhNTUzMDUxMzQ1MTY2NTQzNjBmMzAi_pc
the WHMCS Create project module not send client ID to WHMCS, the result is an correct creation of project but without client assignment
ArshilAhmad
Moderator
Hi @purple,
Please try mapping the Client ID from above and see if it helps you associate a client with the project.
