Woo order > Pabbly actions > error stops following actions
Status: Closed · Asked by Paulius Kazlauskas on · 0 views
human — Question ·
Task History ID: IjU3NjAwNTZiMDYzNzA0MzQ1MjZjNTUzNjUxMzc1MTZhNTQzNiI_3D_pc
i have an issue with a task. Could you tell me why it does not perform?
Problematic task:
Task History ID - IjU3NjAwNTZiMDYzNzA0MzQ1MjZjNTUzNjUxMzc1MTZhNTQzNiI_3D_pc
Working task with same product:
Task History ID - IjU3NjAwNTY4MDYzMTA0MzU1MjY5NTUzNjUxMzU1MTYyNTQzNyI_3D_pc
Similar situation with this task, which used to work and now it does not perform.
Problematic task:
Task History ID - IjU3NjAwNTZiMDYzNjA0MzU1MjZlNTUzZDUxMzE1MTY1NTQzMiI_3D_pc
Task History ID - IjU3NjAwNTY4MDYzMDA0M2M1MjY4NTUzZDUxMzE1MTZiNTQzMyI_3D_pc
Looking forward to hearing from you.
Kind regards,
Paul
Hey @human
We have introduced the "Enable Ignoring Error" feature on our platform to provide you with enhanced control and flexibility in your workflow automation. This new feature, specifically the Skip Step on Failure capability, allows you to optimize your processes by automatically excluding any step that is associated with a failed step during execution. This means that you can eliminate the unnecessary consumption of resources on failed tasks, ensuring a more efficient and streamlined workflow.
Problematic task history ID - IjU3NjAwNTZiMDYzNzA0MzQ1MjZjNTUzNjUxMzc1MTZhNTQzNiI_3D_pc
https://forum.pabbly.com/threads/skip-the-module-on-the-failed-step.14251/
By utilizing Skip Step on Failure, you not only save valuable time and effort but also address the issue of incomplete or missed data within your application. This feature helps to ensure that your workflows are executed smoothly without interruptions caused by errors, improving the overall reliability and accuracy of your automation.
Moreover, you may prefer not to ignore the missed mapped data in the action step. In such scenarios, you can easily utilize the "Disable Ignoring Error" option. By using this option, you can ensure that any missed mapped data is not overlooked, providing you with greater control over the process and allowing you to maintain the integrity of your data.
human — Reply ·
Hello Supreme,
Thank you for sharing this fix with me. It works!
Have a nice day!
