WooCommerce status is not changing always showing checkout draft.
abhay@lagad
i used a WooCommerce trigger as order updated, and capture a response for order updated. but it is capturing the response before i place a order. where status is checkout draft. i want to capture the response after placing the order order in WooCommerce. so how to and also when update the order in WooCommerce from processing t
o completed it is still showing the the order status as checkout draft in pebbly.
ArshilAhmad
Moderator
Hi @abhay@lagad,
The 'WooCommerce: Order Updated' trigger event triggers whenever there is any change in the order status, so your workflow will be triggered for every change, not just for the change of status from processing to completed.
I have added a Filter step to your workflow which will ensure that the action steps of your workflow are executed only for those workflow executions which have the Status as completed.
