Work Flow Not Running After Delay
Status: Closed · Asked by IChild Company on · 0 views
IChild Company — Question ·
Task History ID: IjU3NjAwNTY1MDYzZjA0MzE1MjZhNTUzNTUxMzI1MTY2NTQzNCI_3D_pc
Dear Support
Work Flow Name: V4 Send Fee Report
Task 1 ID: IjU3NjAwNTY1MDYzZjA0MzE1MjZhNTUzNTUxMzI1MTY2NTQzNCI_3D_pc
Task 2 ID: IjU3NjAwNTY1MDYzZjA0MzE1MjZhNTUzNDUxM2I1MTZhNTQzMSI_3D_pc
Task 3 ID: IjU3NjAwNTY1MDYzZjA0MzE1MjZjNTUzMjUxM2I1MTYzNTQzMiI_3D_pc
All the above tasks ends after the Delay.
Hi @ichilddev,
IChild Company — Reply ·
Hi @ichilddev,
Hi hi . Thanks for your prompt reply. Added you as a team member.
Based on your Task History, all three tasks appear to have been executed now.
Weird at the time of reporting the tasks weren't completed. Is there any issue?
To my knowledge, there are no known issues with Delay. It's important to keep in mind that Delay is executed based on the UTC time format, so make sure to adjust the time accordingly.
We have converted to Singapore time to get the expiry date. Should it be executed in Singapore time? Or we need to convert back to UTC time for delete?
Whatever time you feed into Delay, it always considers it to be in UTC format. For example, if you input 2023-07-28 02:00:00 (2 AM) into Delay, the deletion will occur at 2023-07-28 10:00:00 (10 AM) in Singapore time.
