Workflow for woocommerce order update running twice incorrectly?
andrewmeyer
Your Task History ID
IjU3NjYwNTZkMDYzMDA0MzQ1MjZjNTUzNjUxMzUi_pc
Hi there,
I have set up 1 workflow which is only supposed to run once. It is triggered by a woocommerce order update and then sends a whatsapp message. However, the workflow seems to be running twice seconds apart and hence is sending 2 messages.
Don't know why this is happening. Please help?
Thanks,
Andrew
Hello @andrewmeyer
Please check and verify if you have installed more than one webhook in your WooCommerce Account, if in case there are multiple webhooks please delete them and install only one webhook from the trigger step of your workflow.
If there are no multiple webhooks URLs installed in your WooCommerce Account. Then you can test it using Webhook.site how the responses are sent from the WooCommerce end. Please refer to this tutorial to learn how to test using Webhook.site -
If you still face the same issue please let us know.
