Workflows taking more than an hour to execute.
Superfone
Your Task History ID
IjU3NjUwNTZkMDYzMDA0M2M1MjZjNTUzNTUxMzY1MTYyNTQzNzBmMzYi_pc
I have multiple automations running on Pabbly connect. Previously they used to take max 2 mins to execute. Now it takes more than an hour for the second step to execute after it is triggered from the first step.
Luv
Hey @Superfone
Kindly let us know if you can demonstrate filling up the Wix form and your workflow executing in more than an hour via a screen recording. This would be required so that we can look into the issue and offer you an effective resolution.
