Zoom AI meeting recap and Pabbly Connect and Infinity
NicteC
Hello! I'm wondering if there is a way to create an automation that occurs like this:
After a Zoom meeting, copy/add the Zoom AI recap meeting notes to a board in Infinity.
Is this possible with Pabbly Connect?
Thank you!
Luv
Hey @NicteC
You can use Fireflies.Ai for this use case. Kindly refer to this link - https://fireflies.ai/
This application will automatically transcript your meetings and then you can normally record that transcript in Infinity with the help of Pabbly Connect. Kindly set up the trigger step as explained in the help texts in the image below,
After that, you can capture the response in Infinity by using the action step "Create Item".
Kindly set up your workflow and let us know if you get stuck anywhere.
