Zoom connection
lustre
Hello. I followed the instructions to connect Zoom to pabblyconnect in the tutorial
which was very helpful.
All of the steps to setup the webhook looked just like the tutorial. When I fill the Zoom registration form and submit it, the data is not captured in Pabbly.
I have re-checked the steps three times and I can't figure out what step is missing. Please provide some assistance.
Thank you.
Fagun Shah
Is your workflow turned on, make your you submit zoom registration form when workflow is turned on and the wheel is loading showing waiting for webhook response...
lustre
Thank you for your reply.
The workflow is turned on and the wheel next to Waiting for Webhook Responses is spinning. Is there anything else I can check?
lustre
I was hoping this app could work for us, but I'm not able to resolve the workflow issue. - Thank you.
