Xero connect to woocommerce
Supreme
Hey @zaoyao2016
As we can see from your workflow, you haven't configured WooCommerce accordingly.
Please check the following thread to add the Basic Auth plugin to your WordPress.
Then, please use the "WooCommerce: Retrieve a Product by Name or Slug" to retrieve the product id which you can later pass in the Product Id field of "Update Product".
Supreme
Hey @zaoyao2016
If you are trying to update the product in the line item manner then it is not possible to retrieve individual products and cannot pass with line item quantity from Xero.
Further, you can only update products from Xero one by one to WooCommerce.
zaoyao2016
Hi if return the product to the supplier in the xero, woocommerce Will automatically update the product quantity.it possible to do this
Supreme
Hey @zaoyao2016
To update the product in WooCommerce, you need to check first whether the product is present in your WooCommerce or not.
So, kindly try to use the exact name of the product in your Xero and on WooCommerce.
zaoyao2016
Currently My quantity of product a is 5
But I had create a new bills in the xero which is added product a with 3 quntity
Why the quantity product in the woocommerce will become the 3 when i select the updated product
How I make the quantity of product become 5+3=8?
Supreme
Can you please elaborate on your concern briefly with the help of a short recorded video?
zaoyao2016
The scenario is I create bills in Xero, and the quantity of the product will update
On initially of the yam is 10 in the woocommerce, I had to create a bill that added 3 new yam in the Xero, When click send the test request in the pabbly the quantity product in the woocommerce becomes 3. Actually, I want 10 (initial) +3 (new)=13
Supreme
Hey @zaoyao2016
Regarding your concern to update the overall quantity from your Xero along with WooCommerce's retired product quantity, you can use the "Number Formatter by Pabbly: Perform Math Operation".
Kindly give this a try and let us know if that works for you.
zaoyao2016
Hi, I had planned to do this when I create an invoice in Xero, the woocommerce will automatically create the order?
The scenario on my site is correct?
May I know what is the difference create an order and create an order (with line item)?
Supreme
Hey @zaoyao2016
Yes, with the help of this workaround, you can change the number of your products dynamically.
Please give it a try and let us know how it works for you.
zaoyao2016
Hi, I had create a bill with 3 item, but 2 item is broken , So i will create a credit note .
My woocommerce also will decrease the quantity of product after credit note
How i do it because I just see credit note only in the action.
How i connect it
zaoyao2016
Hi May I know if create a invoice with ten product in the xero
After do the connection, They will help me create 10 product in the woocommerce?
zaoyao2016
May I know if I created multiple products in the xero for example 10product per invoice ,they will help me automatically added how many product
Supreme
Hey @zaoyao2016
You can use the "WooCommerce: Create a Product " action step to pass all the supported line items in the product.
Before passing the line Item data in the action step you can process the JSON array with the help of "Line Itemizer "
zaoyao
Hi The data i had map is room fresh and chid but why finally only show me product-6
