Xero connect to woocommerce
zaoyao
Hi The data i had map is room fresh and chid but why finally only show me product-6
Please share the name of the workflow, which you have tried.
As we can see from your screenshot you have passed the multiple line item in the incorrect way. Please check the video tutorial again you will see the manner in which the data should be forwarded.
zaoyao
My web flow name is Xero create bill, woo-commerce create product
I had to check a lot of times. I really don't which are the wrong item
Please help me thanks
Hey @zaoyao
You are supplying numerous product data in the Product Slug and Product Name columns of the Create Product action step of WooCommerce, which WooCommerce does not permit.
zaoyao2016
Hi, I have a question, in regards of the task of Pabbly.
We noticed that the tasks are picked up concurrently and causes the product quantity to be updated incorrectly.
ie:
1. We have a product "happy" with a quantity of 6.
2. Task 1 - Created a bill which will increase the product count -> product from 6 -> 9. (webflow name=Create bill , update product)
3. Task 2 - Created an invoice that deducted the product (the product quantity picked up here is 6 instead of 9 due to the increase by Task 1) from 6 -> 5.(webflow name=Create Invoice credit note)
Kindly check on the above issue, what is the cause of it and how do we resolve?
Can you please explain the situation with the help of a short recorded video?
zaoyao2016
Hi all, based on video 1,
the quantity of product is 6 (beginning)and after the process of updating product it becomes 9
In video 2, the quantity of the product also is 6. (I think the quantity of the product should be 9 because it already run task 1 in video 1)
(video 1)
2)
