Abandoned Cart with data not pulling (Thrivecart)
ArshilAhmad
Hey @victoriahboyd,
Log in to your ThriveCart and Pabbly Connect accounts in an Incognito tab, and re-authenticate the connection with your ThriveCart account. Ensure that you generate a new API key and use this key to re-authenticate the connection. Also, make sure that the product whose abandoned cart you are intending to capture is their in your Product list.
ArshilAhmad
Okay so now that I have it set up, it sent me 4 emails. Is this right?
This issue occurs when a user clicks on the 'Save & Send Request' button multiple times. There are two ways to fix this issue:
  1. Sign in to your ThriveCart account, access the webhooks generated in your account, and delete all except one.
  2. If the previous solution doesn't address the problem, pause the current workflow and create a new workflow from scratch (without cloning).
ArshilAhmad
I'm having the same issue, but before I follow these extra steps, am I understanding you correctly? We need to have multiple connections to Thrivecart? This workflow needs its own? (I'm not a fan of having multiple connections...)
If you are experiencing the same issue of abandoned cart details not being captured, then yes, you need to establish a new connection in an Incognito Tab. You can delete the other connection afterwards.
And will this work when the checkout page is just one page? In your tutorial, the checkout is broken into two page, so the email is captured when the customer moves to the next page to put their payment info in. My checkout page is a single page. So, will Pabbly Connect know that an email has been entered if no buttons are pressed on the page? https://emeraldlakebooks.thrivecart.com/the-art-of-self-editing-challenge
Yes, as long as the email is added and cart abandoned, it should work because the workflow is triggered by cart abandonment and not through the continue button.
