Abandoned Cart with Groovesell
mihirwinson
Hi is there any way to pull abandoned cart data with Groovesell? I tried to create a workflow, triggering groovesell but its only capturing "Product Purchased" data.
Hey @mihirwinson
It appears that Groove.cm currently lacks a webhook trigger event specifically for cart abandonment. To clarify this, could you please verify with the Groove technical team whether such a feature is available or not? If it is indeed available, you can efficiently utilize the 'Webhook By Pabbly' trigger event instead.
