Airtable Connection Not Triggering [Solved]
useer
Your Task History ID
IjU3NjMwNTZiMDYzMTA0MzI1MjZlNTUzNjUxM2E1MTY1NTQzMyI_3D_pc
My Airtable connection has stopped triggering since March 12, even though the trigger event "New Record" keeps firing.
When I manually refresh the fields, the new record shows up, but the workflow is not triggered.
Pabbly13
Hey @useer !
Can you once reconnect your Airtable trigger step with a new connection-
And check further if this is working for you now or not.
useer
The connection keeps running, but never finalizes. I have tried 3 different browsers, all with the same outcome:
Pabbly13
Hey @useer !
Kindly clearout cache from your browser once and try the setup in Incognito mode and check further.
It will work for you.
