Connect HubSpot using pabbly api
Joechew
I’m trying to connect HubSpot via pabbly api. However HubSpot stop giving api. How do I go about it connecting the api?
Supreme
Hey @Joechew
As we can see from your respective workflow, the API key that you have passed might not be a valid format.
Further, we have done some changes in the action step and it is working.
Joechew
Hey @Joechew
As attached in the previous post there is no way i can get an api from hubspot. do you have any guide to link it up? i think it requires oauth authorisation integrations rather than the outdated api now.
Supreme
Hey @Joechew
As per HubSpot's new API, it gets authorized with OAuth 2.0 and which cannot be established on the API by Pabbly action step.
So, if you have any specific requirement with any of the action event of HubSpot then you can post the request here -
Our integration team will look into it and add the action event accordingly.
