Converting and Parsing PDF
LofiJazz
Hi, I need help with a few things:
1. Convert a Google Doc created in Pabbly, to PDF
2. Google Doc created in Pabbly, to set Whoever Has Link Can Edit
3. Parse PDF to extract an email address
4. When a PDF file appear in Google Drive, to grab that new PDF file and parse it to extract an email address
Thank you!
Luv
Active member
Hey @LofiJazz
We will assist your queries altogether.
Here is a video for your use case -
Currently it is not possible to allow edit access through Automation. Although, we have a tutorial for a similar use case. Please try this out -
We would need the application in which you are storing the PDF file to guide you further. Although, you can use "Document Parser" in PDF.co
Further, from the extracted text, you can get the email address by using "Text Parser" in Text Formatter.
