Create invoice with multiple products
Status: Closed · Asked by oscar muñoz on · 0 views
I'm trying to automate the electronic invoicing for my customers' orders on WooCommerce using Alegra. My goal is to automatically generate the electronic invoice through Alegra when a customer purchases one or more products. However, I am encountering two issues:
- When generating the invoice, I receive an error and I'm not sure how to resolve it.
- I don't understand how to set multiple products with their respective prices, taxes, and shipping costs when creating an invoice in Alegra for Colombia.
Although I have read the Alegra API documentation, I am not sure how to correctly place the parameters in Pabbly for the invoice to be successfully generated.
Could you please provide guidance on how to configure this correctly in Pabbly? Any examples or detailed explanations would be greatly appreciated.
Thank you in advance for your help!
Hello @Oscar Muñoz
905 Error means you've not mapped your values correctly or you are passing wrong value or in wrong format.
Hola @Oscar Muñoz
El error 905 significa que no ha asignado sus valores correctamente o que está pasando un valor incorrecto o en un formato incorrecto.Si aún no puedes resolver esto por tu cuenta, no dudes en enviarme un mensaje privado y podemos hacer una llamada gratuita por Zoom. Para tu información, no soy parte del equipo de Pabbly Connect, solo soy un profesional independiente que ayuda a otros usuarios de Pabbly.
No matter how much I check, I don't see where the error is, could we make the call?
Please establish a new connection with your Alegra account and see if that fixes your issue.
I get the same error.
It must be taken into account that my Alegra account is Colombian, for this reason my currency is COP and it is by default, but it does not detect that I have any currency created, and when creating it, the COP currency does not appear since it is by default.
I don't know if that's the root of the problem.
Please wait, we are checking on it.
It seems that you haven't made a new connection with your Alegra account.
Kindly make a new connection with your Alegra account and see if that fixes the 'La forma de pago es obligatoria si se desea emitir el comprobante' issue you are encountering in 'Create Invoice' action step.
