Hey
@Cyrill
You can choose to forward all of your new messages to another email address, or only forward certain types of messages. Set up automatic forwarding You can automatically forward your messages to ano
support.google.com
By default, Gmail allows you to forward emails to a single email address. However, there are some workarounds to forward emails to multiple addresses as well:
Using Filters: You can set up filters in Gmail to automatically forward emails that meet specific criteria (e.g., emails from a particular sender or with certain keywords) to different email addresses. Each filter can be configured to forward matching emails to a different destination.
Using Gmail Forwarding Address: If you want to forward emails to multiple addresses within Gmail's settings, you can create a forwarding address, which is a unique email address provided by Gmail. You can then set up filters or forwarding rules to forward emails from your Gmail account to this forwarding address, and Gmail will automatically redirect those emails to the specified destinations.
Here's how you can set up email forwarding in Gmail:
1. Open Gmail and click on the gear icon (Settings) in the top-right corner.
2. Select "See all settings" from the dropdown menu.
3. Go to the "Forwarding and POP/IMAP" tab.
4. Click on "Add a forwarding address" and enter the email address you want to forward messages to.
5. Gmail will send a verification email to the forwarding address. Follow the instructions in the verification email to confirm the forwarding address.
6. Once the forwarding address is confirmed, go back to the "Forwarding and POP/IMAP" tab.
7. Choose the "Forward a copy of incoming mail to" option and select the forwarding address from the dropdown menu.
8. Decide whether you want to keep a copy of the forwarded email in your Gmail inbox or not.
9. Click on "Save Changes."
Remember, forwarding emails to multiple addresses using Gmail's native forwarding option can be limited to a single forwarding address. To forward emails to multiple destinations, you can explore using filters or Gmail forwarding addresses as described earlier.
