    🔥 Pabbly Subscription Billing One Time Plan for $149 (🏆Lifetime Access) - View offer
Extract pattern is not working
Kenny
I have a text like this below:
0209.jpeg (https://dl.airtable.com/.attachment...9d1d4/WhatsAppImage2022-05-21at6.46.34PM.jpeg)
And i want to extract using below regex:
https:\/\/([\w_-]+(?:(?:\.[\w_-]+)+))([\w.,@?^=%&:\/~+#-]*[\w@?^=%&\/~+#-])
What is got from the result is like this below:
["https:\/\/dl.airtable.com\/.attachments\/c0fa86539533bd72c33d1d1a4d07b8fc\/fc660906\/0209_result.jpg","dl.airtable.com","\/.attachments\/c0fa86539533bd72c33d1d1a4d07b8fc\/fc660906\/0209_result.jpg"]
From REGEX 101, i got the result i want:
Supreme
Hey @Kenny
If you want simply want to extract the image URL from the text then you can use "Text Formatter by Pabbly: Text (Basic Formatting)" which will extract the URL for you.
Supreme
Hey @Kenny
Since you are getting the response in advance the URL is in the array, so you can use the Iterator action step or Line Itemizer action step in your workflow to get it once by one or in commas separated.
Kenny
Hey @Kenny
Before i go any further, would you mind telling my why there is discrepancy between Pabbly and Regex101?
fgsrdsg
It seems there is a bug in general. I also have problems with my Text Parser:
PabblyMember3
Line Itemizer accepts an array of objects with identical keys. It won't work with the direct array of avlues.
Please pass the array of objects with proper keys as shown in the above screenshot. It will work.
Kenny
So, why i can't extract patterns using text extractor (it shows different results from regex101) ? It will simplify my usecase?
PabblyMember3
Can you share the string that you are extracting using REGEX and the expected result of the same?
PabblyMember3
There is a bit difference in the result. Also, I've checked the same https://www.phpliveregex.com/ and it shows a different result.
I would request you try a different REGEX to obtain the expected result.
