Facebook offline connection
Gynette
I set up a Pabbly automation to send back Shopify orders to the pixel as both an offline event and purchase conversion event.
However, the offline event set on Facebook doesn't populate. It still says that no activity was detected.
I'm also unsure if purchase conversion events are being sent back
I've set up a similar automation with Zapier and also Pabbly before , and it worked flawlessly. How do I troubleshoot the Pabbly automation and ensure that both the conversion event and offline event sets? It said it can not find business.
workflow - Viajecito FAAT Framework
Like Reply
Hey @Gynette
Seems like you haven't passed any data value in the action step, please pass the desired fields once and then try agian.
Gynette
Yes but before that, I need to select a business from the drop down menu but there's nothing on the list. I have several business managers in FB but nothing was listed on pabbly dropdown.
Hey @Gynette
Please refer to the following video tutorial once and then try reconnecting the action step again.
(Watch at 7:00)
Hey @Gynette
As we can see from your workflow, you are using an old connection to use the action step.
So, kindly make a new connection and then try again.
Gynette
Still no list on the dropdown menu even I logout and login of both Pabbly and FB. If you can watch the vid I did, upon connecting pabbly to fb for offline conversion, the fb business manager did not pop out but just automatically connect instead.
Try configuring the trigger event once in incognito mode or try logging out of your Facebook account once then try again.
