How can i call a flow from within another flow?
Status: Closed · Asked by ti saigon on · 0 views
i have 3 flow A B C
How can i call flow B and C inside flow A?
Example:
in flow A:
check if x> 10, call flow B
check if x <10, call flow C
Thank you
Hi @tisaigon,
The scenario you have described would function as follows.
Workflow B and C : Add Filter and Data Forwarder as the last 2 steps of these workflows.
Workflow B
Workflow C
Workflow A: To trigger Workflow A using B and C, you need to copy the Webhook URL of Workflow A and paste it into the Data Forwarder of both B and C.
Workflow A
@@ArshilAhmad
Thank you.
But your process is (flow B to flow A) and (flow C to flow A)
My process is flow A to (flow B) or (flow C)
Thank you
i have 3 flow A B C
Example:
in flow A:
Thank you
The workflow I have shared will call workflow B and C inside workflow A.
Would you please be kind enough to share this? I am having the same issue :) Thank you!
There you go:
