How do you access Shopify Product Metafield while retrieving products by ID?
akshayBH23
Hi there,
I'm trying to set up Pabbly Connect Workflow, to fetch the Product details based on the product ID. I'm able to access the details for the product, but it does not retrieve the metafields that I've setup for the product.
I wanted to know if is there a way to access the metafields data also.
Thanks,
Akshay Bhardwaj
ArshilAhmad
Moderator
Hi @akshayBH23,
I'm afraid there is no endpoint available to list the meta fields of a particular Product ID. However, you can try using Shopify's 'List Product Metafields' if it suits your use case.
