How to Configure Opt-in and Opt-out Management in Pabbly Chatflow
Follow these steps to set up keyword-based opt-in and opt-out responses within your Pabbly Chatflow account.
Step 1: Log in to Your Pabbly Chatflow Account
Access your Pabbly Chatflow dashboard by signing in with your credentials.
Step 2: Navigate to Opt-in Management Settings
  • Go to the Settings module.
  • In the navigation panel, click on Opt-in Management.
Step 3: Add Opt-in Keywords
  • In the Opt-in Settings section, enter one or more keywords that users can type to opt in for messages.
  • Use the toggle switch to Enable or Disable the opt-in response message feature.
Step 4: Configure Opt-in Response
Click the Configure button to set up a response for users who send an opt-in keyword. You have two options to define the response message:
Option 1: Use a Pre-approved Template
  • Select from your list of pre-approved WhatsApp message templates.
Option 2: Create a Custom Message
If you prefer to send a personalized message instead of a template, you can manually create a custom response. The following message formats are supported:
1. Text
  • Allows you to compose a plain text message.
  • Simply type your message in the text input box.
2. Image
  • Add a caption along with the image.
  • You can:
    • Upload an image directly from your system.
    • Or provide an image URL.
  • Size Limit: Less than 5MB
  • Accepted Formats: .png, .jpeg
  • Video
3. Video
  • Add a caption to accompany your video.
  • You can:
    • Upload a video from your system.
    • Or provide a video URL.
  • Size Limit: Less than 16MB
  • Accepted Formats: .mp4
4. Audio
  • Add an optional caption with the audio file.
  • You can:
    • Upload an audio file directly.
    • Or provide a URL to the audio.
  • Accepted Formats: .mp3
5. File
  • Upload general-purpose files such as PDFs, documents, or spreadsheets.
  • No preview is sent; users receive a downloadable file.
  • Size Limit: Typically follows WhatsApp limits (recommended < 16MB).
  • Common Formats: .pdf, .docx, .xlsx, .txt
Step 5: Save Your Configuration
  • Click the Save button to finalize and apply your opt-in message settings.
Setting Up Opt-out Keywords
To configure opt-out keywords and responses, follow the same steps above under the Opt-out Settings section in the same module.
You can define keywords users can type to opt out, and configure either a pre-approved template message or a custom message as a response.
