  • Important: Any reported problems and issues with your integration will be reported to you and we will encourage the app developers help to resolve those integration issues.
How to Set Body/Query/Path Parameters within Pabbly Connect
  • Thread starter Deleted member 8616
  • Start date
This documentation provides a detailed, step-by-step guide on how to configure Set Body/Query/Path Parameters .
  1. How to set dropdown field values in the action event:
    • If it is required to generate dropdown field values in the action event, you need to make use of the Inbuilt Action step just above the Action Event API Configuration section by clicking the plus (+) button.
    • Now, select the available inbuilt action events from the dropdown field as shown below:
    • Then, you can define the parameter key for dropdown field.
    • Click on gear icon, then set the label key & Label value in the Dynamic Dropdown (Optional) option.
    • Then you can configure that parameter key and value for the requested raw JSON as shown below:
  2. How to Set Query Parameter Field Values in the Action Event:
    • Set the key for the query field parameter.
    • Just click on the gear icon and set up the field details.
  3. How to set URL param field values in the action event:
    • Set the key for the URL param field.
