How to update custom value on GHL using automation?
nicktsai
i want to create an automation that update a series of custom value on gohighlevel ,
but it seems there is no such feature, how do i update custom values on gohighlevel with your tool?
D
Deleted member 6149
Hey @nicktsai ,
Greetings from Pabbly!!
Please confirm if you are referring to these "custom values". If so, we can certainly check the feasibility with our team and update this endpoint for you.
API Doc:
Awaiting your reply.
Regards,
D
Deleted member 6149
Thank you for the confirmation.
We've notified the integration team, and they are currently assessing the feasibility and working on integrating this endpoint. Once we receive a response from their end, we'll promptly inform you.
Regards,
D
Deleted member 6149
Hey @nicktsai,
Thank you for waiting.
The endpoint you requested is now accessible.
Please review it and reach out if you have any questions.
Regards,
Kater
@Akarshi Can you add the "Update Custom Values" event into "Update Location (Sub-Account)"?
It would be more useful there for client onboarding flows, because using the "Update Custom Values" event you have to manually select the location, which would not be possible if you're creating it in the workflow.
Thanks,
