Incoming WhatsApp messages not showing in Inbox & triggers not firing; outgoing stuck on clock icon
Status: Closed Β· Asked by Dheeraj Goel on Β· 0 views
Hello Dheeraj,
Thank you for reaching out and for the clear description of the issue.
The symptoms you described (incoming messages delivered to WhatsApp but not appearing in the Chatflow Inbox, automations not triggering, and outgoing messages stuck on the clock/pending icon) are typically caused by a missing or incorrect webhook configuration in your Meta (WhatsApp Cloud API) setup, especially when the number was added using the manual token process.
Please try the following steps:
1. In Pabbly Chatflow, copy the Webhook Callback URL and Verify Token from your WhatsApp number's configuration.
2. Go to your Meta App dashboard, then WhatsApp, then Configuration.
3. Edit the Webhook section and paste the Callback URL and Verify Token from Pabbly Chatflow.
4. Verify and save the webhook.
5. Under 'Webhook fields', subscribe to all relevant events by turning ON all the toggles (especially 'messages').
6. Send a test message to confirm that delivery status (check marks) and incoming replies now appear in the Chatflow Inbox.
Reference tutorial: https://youtu.be/JKLboMlmKSs
Additionally, please verify from your Chatflow Dashboard that the WhatsApp number is subscribed. Click the three-dot menu next to the number and select Subscribe to re-subscribe the WhatsApp Cloud API.
If the issue persists after correctly configuring the webhook, please share your registered Pabbly account email and the connected WABA number at support@pabbly.com so our team can investigate further.
Hello Dheeraj,
Just following up to check whether the webhook configuration steps resolved the issue with incoming messages and outgoing message statuses in Pabbly Chatflow.
If the issue persists, please let us know and share the requested details so we can investigate further.
Hi Dheeraj,
Weβre following up on our previous message regarding your query. As we havenβt received a response, this will be our last follow-up, and the thread will be closed automatically.
If you still need assistance, you can email us again at support@pabbly.com to raise your concern.
We would also greatly appreciate it if you could share your feedback on your support experience using the following link: https://www.trustpilot.com/review/www.pabbly.com
