Inconsistent Field Names in Pabbly Automation from Facebook Instant Form Causing Mapping Issues
givage
I'm experiencing an issue with Pabbly Automation where, even though I haven't made any changes to the automation or the Facebook Instant Form, the field names are sometimes recorded in English and other times in German. This inconsistency is causing the mapping to malfunction. What could be causing this problem?
Hey @givage
Can you please share the workflow URL once so that we can investigate further?
Utilizing the 'all leads' ad forms option in the trigger event may result in field names appearing in German in one lead ad form and in English in another. It is advisable to create separate workflows for each form. The German key fields originate from your lead ad form titled 'AiL Lübbecke (Nicole Jarosch)-Form-v1'.
givage
Ok thank you so much for your analysis and the solution. I was just wondering because the new Form was only a minimal description change and had nothing to do with switching language or renaming the buttons. Alright then, I will always choose the right form! Thank you :)
