IP address (or range) for white listing
Status: Closed · Asked by flauwer on · 0 views
flauwer — Question ·
Hi there,
I use pabbly to send information to a API endpoint.
However, for security reasons, I need to white list the IP no. of the POST webhook API (or range of IP no.s).
What is the IP range of Pabbly Connect POST webhooks?
Best regards,
Thomas
Pabbly — Reply ·
Hi there,
Best regards,
Thomas
Here's the Pabbly Connect IP - 44.224.102.169
Hello
I have a Problem when I send data API:
Error of the SERVER:
IP 2600:1f13:7cb:8700:e267:288:f429:3cf4 not allowed
The support of the server:
"The IP of affiliate is correct 44.224.102.169 but their network/server go out with another IP. This IP is IPv6, but we need IPv4."
It is possible to place a field or command to send another IP?
Thank you
Rolando Segovia — Reply ·
It's Solved!! thank you
