How to have re-execute tasks that fail or partially fail?
Status: Closed · Asked by Behzad Jazayeri on · 0 views
We have multiple workflows that work with Google Sheet for adding data. These workflows often get 503 errors. The re-execution is set automatically but often time even the re-execution fails. Is there a way to have these re-execution run again if all attempts fail due to 503 error?
Hi Behzad,
Thanks for reaching out.
The 503 'service unavailable' errors you're seeing on your Google Sheets steps are a temporary outage on Google's side, not an issue with your workflow configuration. Pabbly Connect's auto re-execution retries failed tasks on a fixed back-off ladder (roughly 5 min, 15 min, 30 min, 1 hour, 2 hours), up to a maximum of 5 attempts. Once all configured retries are exhausted, the retry path is paused and a failure email is sent, so re-execution won't automatically run again beyond that cap.
At that point you would need to re-execute the failed run manually:
1. Open the failed row's detail drawer and click Re-execute. You can choose a full re-run or 'from the failed step onwards'.
2. To handle several at once, select multiple failed rows and choose Re-execute selected (Failed only, or Failed + skipped).
Is there a way to make this re-run also automatically?
Hello Behzad,
Apart from setting up a number of retries in the Auto-re-execution setting, there is no other method to re-execute the failed/partial failed task except to execute it manually.
Adeel Akhtar
🌐 Pabbly.com
So we cannot create another workflow for this?
Hello Behzad,
No, task re-execution can be performed manually, not automatically.
Adeel Akhtar
🌐 Pabbly.com
