Is it possible to connect Sage Accounting with PABBLY connect?
ArshilAhmad
Moderator
Hi @Jordan Darlison,
If you want the Sage Accounting application to be integrated with Pabbly Connect, you can submit your request on our dedicated platform: https://pabbly.featureos.app/b/Integration-Request
Our integrations team will review your request and, if possible, add the desired application to Pabbly Connect.
In the meantime, if Sage Accounting supports webhooks or has a REST API, you can try using the Webhook by Pabbly and API by Pabbly modules to execute a trigger or action event.
