issues with 360dialog integration
Salil
facing issues regarding 360dialog integration. Whatsapp messeges are not being sent . new API key showing invalid. is it with pabbly or 360dialog ??
No help is being given. Earlier the integration used to work just fine but since 3-4 months, its not working at all.
Can you please share the workflow URL on which you have tried the 360 Dialog action step, so that we can look into it?
