Limitation for iterator & get rows
Status: Closed · Asked by 99 Interactive on · 0 views
as per my understanding, please correct,
1. iterator can work for 500 GS rows (max)
2. get rows for how many records can be fetched ?
Hey @99 Interactive,
1. Iterator can process more than 500 rows
2. It can retrieve data up to the maximum number of rows in your spreadsheet.
It means GETROWS can fetched all the available records at once .?
Yes, you just need to specify the range and it will fetch the date in that range.
