Mailchimp too many simultaneous requests
I am trying to pull 10000 clients from Mailchimp into GoHighLevel.
But I am getting this error:
How I can setup pabbly to only serve 10 requests at a time? Maybe serve 10 requests every minute?
Pabbly13
Hey @RaptorsRush !
Kindly use the "Delay" module for up to 2 minutes, so it doesn't error out for you-
You can check for this video tutorial on how "Delay" works-
Kindly check on this and let us know if this can work for you.
The requests are being sent in bulk from go high level. I need to parse the requests and break them up into chunks of 10 and then send each chunk individually every 2 minutes.
Hey @RaptorsRush
You can use the "Delay" action step to hold the execution of some instances so that you can avoid the "Too many requests" errors by the API.
Moreover, you cannot hold executions and then execute them after a time.
