MMS Alternatice than Twilio?
Status: Closed · Asked by Bananajuice2002 on · 0 views
I'd like to ask if you have any integration options other than Twilio that would allow sending MMS messages in bulk?
Hi @Bananajuice2002,
You can try using Clicksend: Send MMS action event for your use case.
You can also look into our Integration list to find any other alternatives.
Pabbly Connect Integration list:- https://www.pabbly.com/connect/integrations/
