Need help in creating a workflow
I want to create a workflow like this:
Data is saved on my google sheets with these details:
date
name
email
whatsapp number
Delay for 1 day and then send whatsapp message but it should be between the office time range (between 9 am to 7 pm) as I don't want to disturb them in odd timings.
Please help me with this.
Thanks & Regards
Rachna
7011030909
date
name
email
whatsapp number
Thanks & Regards
Rachna
7011030909
Do you have any fix time for sending messages? Or is that random between 9 am to 7 pm?
Hey @rachnanaisha
We are currently looking into the possibility of your use case and will update you soon.
Thanks for your kind patience.
Hey @rachnanaisha
As per your concern, we have created a workflow on your terms. Kindly check this in your account and configure the Google Sheets Trigger and the message sending API in the last step. Although we have fixed the delay time of your message to 11 AM ( UTC 5:30) by the delay action step.
