Need Help with Pabbly Connect Workflow
Hi @Resham,
I deleted the Pinterest step and added it back in. I submitted a test and will let you know in a couple of hours if it worked.
Hi @Soumya Tripathi @Preeti Paryani,
Good day. I just want to let you know that this issue is Not resolved yet.
I created a new workflow and got the same error.
Can we resolve this please?
Hello @fredkennethuy,
Our team has implemented some fixes, and the issue should now be resolved. Please recapture a response from the trigger step, run the workflow in automation, and let us know the outcome.
Hi @Preeti Paryani,
It still didn't work. I created a new workflow configured exactly the same to try it out, but it still gave the same error.
Hi @Preeti Paryani,
The date formatter step is necessary because Pabbly does not accept dates with "Z" at the end. (Attached the screenshot).
Also, we never had an error with the date formatter step. The errors that we are getting are from the "Get Record" and "Pinterest Create Pins" steps.
I understand that the issue is not with the Date/Time Formatter. To assist you more effectively and review the setup in real time, we’d like to connect with you over a Google Meet.
Please let us know a convenient time for you to join us between Monday to Friday during one of the following slots:
  • 11:00 AM – 1:00 PM IST
  • 4:00 PM – 5:00 PM IST
Kindly share your preferred time, and we’ll schedule the meeting accordingly.
Would you be available to join us at either 4:00 or 4:30 PM IST? Please let us know so we can schedule the meeting accordingly.
Kindly note that if the meeting is scheduled for 5:00 PM IST, it would fall outside our usual meeting hours as our shift concludes at 6:00 PM IST. In that case, we would have to wind up the call within 20–30 minutes.
We have scheduled the meeting for today at 4:00 PM IST. Please note that tomorrow is a local holiday (Ganesh Chaturthi), so we will not be available to connect then. Kindly let me know if you are able to join today’s meeting as scheduled. If not, I can reschedule it for a later date.
