OpenAI step: allow dynamic/latest model instead of fixed model selection
Status: Closed · Asked by Jonathan Baillie on · 0 views
I use the OpenAI action in Pabbly Connect, and the model field currently requires selecting a specific model from a dropdown.
The problem is that models eventually become deprecated or obsolete, which means a workflow that is working fine today can suddenly start failing later. At that point, I have to wait for the error, identify that the model is the cause, and manually update the workflow.
It would be much better if Pabbly could support one of the following:
- a “latest” or “recommended” model option
- the ability to enter a custom model ID manually
- a dynamic/custom-variable model field
- some other way to automatically use the current supported model without editing the workflow each time
Ideally, I’d like to avoid having to wait for a workflow failure before discovering that the selected model needs updating.
Is there currently any way to do this in Pabbly Connect? If not, could this be considered as a feature request?
Hello Jonathan,
Thank you for your feedback regarding the OpenAI action step in Pabbly Connect. Currently, the model field does require selecting a specific model from the dropdown, and there is no option for a dynamic or custom model ID at this time. Your suggestion for a "latest" or "recommended" model option, as well as the ability to manually enter a custom model ID, is valuable and can certainly help improve the user experience.
Since we get a lot of integration/feature requests on a daily basis, we have added a request board to organize customers' requests and feedback.
You can add your request to the board, and others can also upvote so that we can add new integrations on a priority basis based on the feedback.
I would request you to please fill add your request to the board itself.
Please send us the request here for the new integration/feature - https://pabbly.hellonext.co/b/Integration-Request
Our team will review the request and possibly add the integration soon if possible.
Adeel Akhtar
🌐 Pabbly.com
