Chatflow — incoming messages with BSUID-only identity
Status: Closed · Asked by Izzat Akarim on · 0 views
Could you please share the Chat ID where the AI Assistant didn't work? Also, are these messages appearing in your Inbox?
Please access my account. This is a public thread. Thanks.
🔐 Private credentials requested
A secure link has been sent to your registered email. Open the secure form — visible only to you when signed in to the forum.
We have shared a secure link with you. You can use that link to share the Chat ID with us.
I have shared the task ID. please advise where to get the chat ID if it is the wrong id requested. task ID is in pabbly connect.
chat is not stored in chatflow inbox
Thank you for confirming that the BSUID messages are not appearing in your Inbox. We have forwarded this concern to our technical team for further investigation. We will get back to you once we receive an update from them.
We checked this with our technical team, and they confirmed that the webhook is receiving a contacts section, but it does not contain the actual contact information. As per Meta’s latest changes, this section now appears to provide username information instead.
Currently, Pabbly Chatflow does not support this information. As a result, these messages are not visible in the Inbox, and the AI Assistant is unable to respond to them.
Our team plans to add support for this information in a future update.
Hello there,
I hope you’re doing well. I just wanted to follow up regarding our last message.
Adeel Akhtar
🌐 Pabbly.com
Pabbly Support:
Hello there,I hope you’re doing well. I just wanted to follow up regarding our last message.Thanks & Regards,Adeel Akhtar🌐 Pabbly.com
Hello.
What were you following up? I am still waiting for pabbly chatflow on the BSUID update.
Thanks.
Hello there,
We plan to add support for it in the future. For now, these messages will not be visible in the inbox.
Adeel Akhtar
🌐 Pabbly.com
Pabbly Support:
Hello there,We plan to add support for it in the future. For now, these messages will not be visible in the inbox.Thanks & Regards,Adeel Akhtar🌐 Pabbly.com
Great! I hope it will be sooner!
Absolutely! We’ll do our best to have it available as soon as possible. Thank you for your patience and understanding!
