pabbly connect with project broadcast
Your Workflow URL
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZjMDYzMTA0MzQ1MjZjNTUzZDUxMzUi_pc
Your Task History ID
IjU3NjEwNTZmMDYzNjA0MzI1MjZmNTUzNjUxMzQ1MTY1NTQzNSI_3D_pc
I'm using pabbly in conjunction with project broadcast. I have a wix form sending info to a google spreadsheet and then to PB to send an SMS message to the customer that fills out the form, telling them "Thanks for filling out the form and I will get back to you asap, etc". Now I want to send another text to my direct phone number so that I get a text notification when the form is filled out. I have tried a few ways to go about this.
1. Since I am my own contact in project broadcast, I used the “search contact” action. When I entered my first name, last name in the search content area, the test works and Pabbly can find the contact. But when I try sending a message using that contact 0 id from that search, I got an error that the contact was not found.
2. I also tried searching for myself with just my phone number and got another successful response from PB. But when I tried sending the message with the contact 0 ID and a different test with the contacts 0 phone number, the send message error said contact not found for both different tests.
Can you please help me figure this out? I'd greatly appreciate it.
ArshilAhmad
Hi @thehunt4joy,
Please ensure that you map/enter only the Contact ID and not any other text. I have removed the text for now, and it appears to be working fine
Ok thanks! I think that was part of the map info that I clicked so I just assumed that leaving it there was ok. Good to know that it's not ok for next time. Thanks again!
