Pabbly Router logic not working as expected -- Please help!
It seems Pabbly Router thinks the first number is much larger than it is, or the second number is much smaller than it is (possibly null or negative?), or both?
Source: https://connect.pabbly.com/task/history?filter_status=applied&filter_by_workflow_id=IjQ3MjAwMCI_3
Thank you,
James
Franklin Services
